clear case cleaning
xdollface8
76
How are you cleaning your clear cases? Mine gets a little dirty sometimes. A simple wipe leaves it with streaks or clouds.
Use a Toothbrush to Clean Your Case. To remove mild stains, dust, and grime from your silicone case, use warm water, dish soap, and a toothbrush. If you have only mild stains or your case is dirty with dust and grime, then all it needs is a good wash. Grab a small bowl and fill it with warm water and dish soap
Bruks Apps
