*Click* *click* any way to change it?
adellc3
266
9
Is there any possible mods that you guys know of that changes the sound of the click sounds when you tap something? You know, when you go to open an app or app drawer, it makes that *click* sound? Does aany one know if there's a way to mod that?
Sent from my Fascinate using Tapatalk.
You can change out the system sound file for one of your choice using Root Explorer. I'm pretty sure the file you want to replace can be found here:
/system/media/audio/ui/TW_Touch.ogg
You would just rename the ogg sound file you choose TW_Touch.ogg so it takes the places of the original. (I would first rename the original by adding .old to the end, thus making a backup.)
Reactions: adellc3
BablisKhatun
