Clicking sound through headphones?
ecpolo521
47
I've noticed that I get a clicking sound during a call or listening to music with the headphones. The clicking stops when I pause the music or end the call. Is anyone else having this issue?
I tried 3 different headphones and all had the same issue. I then went forward with doing a factory reset and the click is gone now. Hopefully this helps if anyone else is having this issue.
EDIT: Found out it was Screen Notifications causing issue. No need for factory reset.
I had this issue also. On mine it turned out to be an app that I installed causing the problem.
I found the source of the problem.
Any app that monitors the proximity sensor will cause the clicking sound in my headphone.
hey, im new to this.
i've tried to disable the monitor proximity sensor but still the noise is there. i dont see any notification on the upper screen.. so where does it come from?
can some one give me some more details or step by step solution?
tnx
