Clockwork problem Evo3d
clj1973
3
no errors during hack [HTC Unlock Method]. I can use apps that require superuser fine ex. wifi tether and titiaum backup. the problem is when i open colwkwork mod i cant backup my ROM. the phone reboots and no backup is made. also the "flash alternate recovery" is grayed out. I want to back up my ROM before i try Viper.
clockwork flash clockworkmod recovery @ 5.0.2.0
beezy
2,434
1,010
Have you tried to boot into recovery manually or adb reboot recovery then make your nadroid back up
radiation0512
71
3
Had the same problems but all was solved after switching to TWRP...just a thought.
Sent from my hacked up 3VO!
jamesjeter1
Active member
Aug 21, 2011
25
there is only 2 know recoveries that will flash if you unlocked the HTC way There is a modified twrp and an older crw i have used both. I started with cwr but now Im on the twrp.... i have both of the recoveries .img if ya need them
jamesjeter1
Active member
Aug 21, 2011
25
look for cwm-4.0.1.4-shooter and twrp-1.0.3-modifiedi know that both of these works well
Captain Fluellen
