CM 10.1 and roaming issue
ericinaz
69
Does anyone know if they fixed the issue that after installing 10.1 your phone roams until you ODIN back to stock? Do I have to do something else first to prevent this like go back to an older stock ROM first?
Sent from my SCH-I535 using Android Central Forums
I'll try this. Thank you very much..
stay on CM 10.1 and I then had to check the "mobile network" settings and change it to SIM card (instead of NV) then reboot, and it worked.
mrrice360274
