CM 11 Battery Drain founded Sloution works with my NEO V
amilatn
4
Guys,
i install cm 11 for my neo v..bu battery drain fast...when i fully charged 100% at night...when i got up morning it's 70% battery standby
SO here is the sloution
connect your charger to phone
then off the phone with out removing the charger
(then phone automatically charging)
then again on the phone with out removing the charger
and let it to be charged 100%
then see the battery works fine
it's work for me....
Thank you for sharing your experience, which may be helpful to others. When you refer to turning your phone off, do you mean a full Power Off, followed by Restart? If so, you are performing a Soft Reset which may well stop whatever it is that is causing abnormal battery drain.
draikin1
