CM 6.1 Battery
jnl813
769
21
:mad:Is there anyway to change the battery in CM? I hate to see the percentage that I have left. Is there anyway to change this?
Just go to menu, settings, cyanogen settings, user interface, battery percentage.
If you installed the REVO battery mod with the circle on your theme though then it's there to stay (i believe, haven't tried to change it)
No i didnt but i would prefer that one, do i need to go back into recovery and install it?
Also Fred why do I need to do this?
Also of note in CM6 roms (theme or not), at any point after installation you should go to menu settings cm settings, performance settings, vm heap size, change it to 24, reboot normal, go back to the same place and change it back to 32 and reboot normally again. For some reason though it says 32, it never really is until you do this.
__________________
Fred
@thefredelement | Rooting PSA - The more you know
On the Bliss HD post just grab the zip at the bottom of the post and install it via recovery, you don't need to wipe or anything.
__________________
Fred
This will make it a bit faster and will let some programs run better (Vignette for one if you use that camera app)
Doing this as we speak.... thanks Fred, man i thought i bricked my phone when trying to install that theme! And you never replied to that post so I decided to just go into recover, and then re boot, i never went into the setting to add the theme like you said.
I went into settings/user interface, battery percentage, turned off, but all it did was gray i out, but still there. So i went back to Evervolv's ROM with Android 2.3. I love CM butknowing how much percentage i have left is a constant reminder of how bad my battery can drian, or how bad i need to charge it.
Check out the Bliss HD theme post again, he added some battery mods - You may have to re-flash the theme and then not install any battery mod to get rid of the percentage.
I wouldn't tell anyone what to do with their phone but CM takes a little tweaking, especially with a custom theme to get it all how you want it. If you like what you're running now then though, don't worry about it!
Rehan10w
