CM6 install problem
tizio
6
Ive been trying to flash CM6 on my evo today with no luck. I keep running into a status 7 error when I try to install from the zip. Currently I am running RvU 1.3.2 with Clockwork recovery (installed using unrevoked2).
Is there something that I am missing? Ive tried out many different roms before with no problems with the install. Please help! I would really like to test out some of this froyo action!
Something about *RU.BOOTLOADER*?
Check out my thread about said issue if indeed it is the same message...
yes, I have Nand unlocked. I've never had a problem when it came to installing a custom rom until now
Because Unrevoked does not install Engineering HBOOT which is what you need to flash this... As i found out the hard way...
I just got to page 3 of your thread and I'm a little lost on how to get engineering hboot installed.
Try using simpleroot to unlock nand. If that doesn't work do part two of toast's instructions.
Sent from my iPhone j/k!
Sheesh. This is happening to me too. So a SimpleRoot unlock should fix this, eh?
Unrevoked eff'd up a lot of people's stuff.
I am currently running Fresh and wanted to check out CM6. It's odd that other roms will work. I'll give this a shot tonight when I get home, I suppose.
akununtukunduhfilm2
