CM7 stable and nightly not connecting to Bluetooth
uidb5259
3
Ok, so I have a SF using CM7, both the stable and nightly releases, and I cannot connect to my bluetooth headset. I tried the headset on my wife's stock SF and it worked fine. When I start bluetooth it turns on and sees the headset but it will not connect. Is anyone else having this issue? I have searched the forums and have not found any issues connected with the SF.
Try CM 7.1 its for the fascinate and I have no real issues with it. My BT works fine
Sent from my SCH-I500 using Tapatalk
I had the same issue with my car, but rebooting the phone seemed to fix it although I'm sure you've turned BT off and on as well...
This is a common issue with cm7 if you drive a ford. Its one of the reasons I stopped using it. I'm back on PowerWashed GB and very happy everything works.
devicedecode
