Comodo battery saver
tigerNamedtony07
140
Trying this battery saver app a friend recommended to me. I actually like it because it has all the settings (brightness, wi-fi, 3g/4g, bluetooth etc) and a little meter that goes up and down and tells you how long your battery will last when you turn one of those features off or on or switch to different brightness) Well i notice it says my phone is using 70 % of android systems. Could the app be causing this?
I figured it out. Called htc. Told ms to plug in and turn off phone. Than hold volume down up and power same time. It will restart. Android system is down. And battery life was good today. 16 hours with 34 percent left
Thanks for the follow up. Hope that helps. See you around the forums.
Bry
