Computer not recognizing phone when in USB Debugging mode
sinfony78
Active member
Feb 1, 2011
35
I have both XP and Win7. Right now I'm attempting this on XP.
This started when I tried flashing SFR 1.1.1. When I did it (and after several reflashes), none of my computers could recognize my phone (could not get USB connected in USB Debug and non-USB Debug mode). I've flashed back to stock and it works in non-USB Debug mode only. Trying to flash CWM3, but can't since the phone is not recognized with USB Debugging on. Tried reinstalling USB drivers from the Samsung site several times already. The only thing I can think of that happened is that right before flashing SFR, I had to Odin to EC05 modem. That didn't take the first couple of times. Finally took, then flashed, then got problems.
Any ideas how to fix?
Possible suggestion here... Odin to EB13 and see what happens... I've heard of some problems with Odin to EC05. From what I understand the Odin tar that is being used is NOT official from Samsung/Sprint and has caused some issues. I for one haven't had any after using a few times but others like yourself have.
Try Odin to EB13 then attempt your rooting.. Once you flash a EC05 based ROM your basically converted to EC05 anyways so it really doesn't matter how you started out.
I've had the same issue in SFR 1.1.1 trying to get my USB to work on Vista. Seems, for me, only one particular USB port will recognize my cable. Plus, just when you decide to Odin, shut down the PC & restart, then go straight to Odin & the particular USB port & it works...go figure. This is all while in debugging mode.
Debugging mode shouldn't even be an issue because when your in download mode to use Odin I don't believe debugging mode is even active at that point. Of course I could be wrong.
looks like i am having issues installing the driver for "Android USB Modem"
i actually got the OTA update and am now on Froyo EC05 after flashing to stock, but cannot install that one particular driver, even tho i just reinstalled the driver package from Samsung (i'm on my win7 laptop now, btw)
i think i'll have to just Odin EC05/CWM3/EXT4 to get around this issue so i can flash ROMs
BablisKhatun
