Constant freezing??
maverick96
989
10
18
I have to re-boot this thing at least twice a day due to it freezing up on me??? When I tae a picture then try to tap on the pic to see it the X almost always freezes up on me? Why is this? Is it because I have a task killer installed on the phone? Is anyone else noticing freezing on their phone?
I havent experienced one problem. No freezing, no rebooting, its been nothing smooth and flawless. There really is no reason to install a task killer though. Android manages memory very well.
Yeah I just deleted the task killer now and I'm hoping that was the culprit, otherwise I will have to search some of my other apps to see if they are causing conflict or something.. Do you know of any apps that dont play nice with the X?
I had this issue the first day I had the X, I found the task killer app was killing all during screen off. Since I disabled that it has been fine. I wonder what app can bring down the OS?
None that would completly freeze the device. Usually it is the app that freezes and you have to force close it. If it continues to do it you may want to think about bringing it back and swapping it out.
Your right and thank you for the help...
mari_rod
