Could Gingerbread 2.3.6 Different Build Dates cause Battery Drain?
thomtwo
3
We have identical Samsung i827 Appeals.
One drains the battery when TURNED OFF in 6 to 7 hours.
The other's battery maintains a reasonable charge durning the same time period.
The only difference is the 'Build date of the Gingerbread OS' (see below)
The one that doesn't hold a charge is GINGERBREAD .UCLE3 built on Mon May 14 10:06:36 KST 2012
The one that stays charged was built date is GINGERBREAD.UCLJ2 Tue Oct 30 17:34:10 KST 2012
Could this be the difference???
--SEE LINK FOR DETAILS-- OpenBuildProp
If your battery is draining while the device is turned off, you have a hardware fault. If you mean draining while in standby (screen off, not using it), then yes -- different builds can act very different. I would research why the earlier version hasn't been updated.
Do any of you folks know where I can download 'Kernel builds' to flash and match the two Appeals with the same builds?
sulanku9
