Could some Gear owners help answer a couple of questions please.
RetroGlide08
6
As a van driver I'm thinking the Gear could be handy by keeping my phone out of sight in the van as I deliver but I'll still be notified by the watch of calls/messages etc. My question is, if I were to leave the van to make a delivery would I have to reconnect to the phone upon returning to the van? Would I also be notified when I return to the phone of any missed calls via the Gear once reconnected?
Thanks in advance for any reply 👍
Sent from my SM-N9005 using Tapatalk 4
Yes. If you walk out of phone range with a gear on, it will disconnect then reconnect upon re-entering range. It connects/pairs w/ your phone via bluetooth. As for "missed" notifications, I haven't seen that happen yet. I'll have to try that part out tomorrow.
What happens if you have Ford Sync in your car where with the calls go would you still be able to use sync and the watch to
Sent from my SCH-I605 using AC Forums mobile app
The phone can accommodate multiple devices connected via bluetooth.
I don't have Ford sync, but when driving I do connect my visor bluetooth speaker and haven't had any problems.
I'm not sure how Ford Sync works, but in principle it should work.
Correct as long as your choosing your primary source when pairing should work just fine.
Ditto on second comment. When in range will re synch and notify of anything missed
Sent from my SAMSUNG-SM-N900A using Tapatalk 4
But you can't split phone audio twice if Ford Sync has phone audio and media audio can you still keep to watch connected too?
Thanks in advance for any reply 
says in the gear manger under notifications that the next time they connect anything missed on the phone will show up on the gear....
I have Ford Sync and the watch. Both sync simultaneously and for me the calls defaulted to the Ford sync and the watch was still connected.
Sent from my SGN 10.1 2014 Edition Using Ac forums mobile app .
Lucky you. When I get into my car with Ford Sync I get a message on my phone that says my watch has been disconnected. When I spoke with a Samsung Tech, he said it was 50/50 as to whether it would work or not.
I am okay with it I guess. Better my watch is disconnected than my Ford Sync not work.
