Cpu Overclock Help!!
KidFr3sH
171
5
Wenever i overclock even to 729 it reboots and just keeps on rebooting barley got a new optimus v any suggestions ??
Yeah if I even overclock mine even a little bit it spazzes out. I guess our phones just "barely" met specifications...
Is it a warrenty replacement? Mine is and does the same thing.
Sent from my VM670 using Tapatalk
Guess I'm lucky. Mine doesn't have any freakouts til I'm at 825Mhz.
Vaguely remember reading that people had varying degrees of OC success with various ROMs. Have you tried several ROMS to see if different ones gave you more ability to OC?
No processor is exactly the same. None are perfect, since they're so freakin' small. The processor would and could be a lot more powerful if they were prefect. But each processor in the phone isn't exactly the same, so everyone may have a bit different results when overclocking. :-\
I'm wondering if any of you might have better luck with ICS once it's stable enough for your tastes. Its kernel has a few more governor options. It likely won't make a difference, but it would be interesting to see.
I've actually had stability trouble in ICS without even OC'ing. It always overheats.
I want my old OV, overclockable to 864. This one goes to 806 and reboots or freezes after 3 minutes.
I can now see why you guys complain. :p
hmm.... i have mine running on performance 24/7 at 864, i never have problems. zips through processes like nothing. try a full wipe and do a long battery pull.... maybe resetting the internals would help.
What does resetting the internals even mean?
pull your battery out and wait 10min. your clock will have the wrong time, the date will be wrong, etc. its a way to fully reset everything running and give your phone a break. it's no genius trick but it helps a lot of situations. it wouldn't hurt to try it anyways.
pretty shocked you've never heard of a battery pull.
dmflowsjalallodhi
