cracked screen from corner to corner on tablet
Amy Wickam
I taped the screen to at least be able to use it alittle but keep having to rotate the tablet cause certain spots will not work! Does it need more tape I dont understand how some works butnot other part
wizzrah
Retired Ambassador
Jul 27, 2013
4,686
You might need to go get the screen repaired. It sounds like the digitizer is damaged if some spots don't work.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Part of the screen was probably damaged which is why it isn't working
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,380
127
63
I have had friends use tape to fix screens, but that was after they confirmed the glass was the only thing damaged. Since certain spots don't work the digitizer was damaged and probably needs to be replaced.
From a Liquid Nexus 5
Hermes14
