criket flash problems?
josney
Active member
Oct 24, 2010
40
hello all,
complete noob here. my son was given a droid and we had the phone flashed to criket. the phone acts fine as far as calls, text and general use. the phone was fully flashed to enable internet. as long as he is connected through wi-fi, he has no problems. standing in the store after the flash and about 20 minutes up the road, all was fine. he has an SD card installed. he got an error dealing with the card, he removed the card and has not been able to access internet. does this have anything to do with the sd card or the criket flash? thanks for any input
This link might help:
How to Flash MOTOROLA DROID to Cricket: 2.2 Froyo FULL apps,web,mms - xda-developers
This is also a quote regarding the internet when flashing to cricket:
As far as web goes, there are 2 settings that need altered. The first is the APN your phone uses. The default is set to Verizon, and thus you will never get internet access. Click ?Voice Dialer? and say ?Open APNs? then you?ll need to change those settings to cricket?s information (these settings can be found on google). After that you?ll need to edit the internal information in regards to your network. This is found by using QPST and a virtual serial port to read your phones information, you then write ?yournumber@mycricket.com? and the password which is ?cricket? to the phone and you?ll have internet access.
mannanqureshi
