M mattias1 New member Dec 11, 2015 2 0 0 Dec 11, 2015 #1 custom sound mode? How do I create a "custom" sound mode on my Samsung Note 4? I want to create a "work" sound mode (lower volume than normal but note vibrate only or completely off). Can this be done via a setting or is there a good app for this?
B. Diddy Senior Ambassador Moderator Mar 9, 2012 168,202 8,764 113 Dec 11, 2015 #2 Re: custom sound mode? Welcome to Android Central! Try Llama.
M mattias1 New member Dec 11, 2015 2 0 0 Dec 11, 2015 #3 Re: custom sound mode? Thanks B. Diddy. I dont keep my location services on so is there any app that I can make a "work" sound mode for that i can turn on and off manually?
B. Diddy Senior Ambassador Moderator Mar 9, 2012 168,202 8,764 113 Dec 11, 2015 #4 Re: custom sound mode? How about Audio Profiles? If that's not what you're looking for, then try some of the Similar Apps that are listed.
