Customize Nexus Lock Screen and Home Screens
DeathByBFG
Active member
Oct 25, 2012
34
I feel really stupid asking this but I can't seem to find it in my Nexus's settings. Anyways how can I customize my Nexus? Specifically I want to be able to add widgets to the lock screen (including the little circle that you use to swipe to unlock) and tweak my main screens. Where do I go to do this? I'm used to my Galaxy S3 but for some reason the Nexus is giving me issues.
Thank You!
if you swipe the widgets on the lock screen it would give an option with a + sign to add widgets.
to customize your lock screen use an app called widget locker.
Ah. So I can't put widgets on the illuminating lock circle without widget locker?
yes, you can without widget locker. press and hold a widget in the lock screen. it will let you move the widgets.
move the widget you want to the right end and it would be displayed on your lock screen
I don't think this is correct. The question is if a widget can be placed on the slide-to-unlock lock circle on the lock screen. I don't believe this is possible with stock Jellybean.
maybe i misunderstood the question. yes, its not possible to place it in the circle without an app.
but with 4.2 you can place supported widgets on the lock screen.
Exactly--we just have to wait for devs to come out with more lockscreen widgets!
DannyTG
