S saiyantwin1985 Member May 16, 2010 9 0 0 Jun 5, 2010 #1 does the new damage control come with root access or do i have to do it cuz i cant run setcpu
A Andrew Ruffolo Well-known member Jan 5, 2010 3,567 172 0 Jun 6, 2010 #2 It comes with root, it does not come with overclocked kernel.
S saiyantwin1985 Member May 16, 2010 9 0 0 Jun 6, 2010 #4 and for some reason the live wallpaper doesnt stay in the screen it goes bak to the normal wallpaper. is there a way to fix that
srkmagnus Retired Moderator May 23, 2010 13,431 210 0 Jun 6, 2010 #5 If you are not using overclock then I'd suggest not using SetCPU as it won't give you any benefits. With the live wallpapers, download the file provided by Damage to make them stick: [ROM] DamageControl v2.09 | Final Sprint RUU, Deodexed | Final Hero build - xda-developers
