Dashclock Battery Extension Help
jrwestenberg
Active member
Apr 22, 2011
41
Hey guys,
I have a question about the Dashclock Battery Extension. I have a New Nexus 7 and a Verizon Galaxy Nexus, both in which I am running Dashclock with the battery extension. On my Galaxy Nexus, I have checked all boxes next to "Discharging, Charging, Not Charging, and Charged". No matter what I check/uncheck, my G-Nex only displays 'Discharging' when it's not charging. However, on my New Nexus 7, I have all of the same settings selected, and it reads 'Not Charging' instead of 'Discharging'. I'm trying to figure out how to get it to read 'Not Charging' on my Galaxy Nexus.
Does anybody have any advice? I have already uninstalled and re-installed the app, and no luck.
Please and thank you!
-Jimmy
It SHOULD be reading discharging. Any time you're using it without it plugged in, it's using battery, thus discharging the battery.
Hey Scott, thanks for the response. Why would my Nexus 7, which has the same settings, display 'Not Charging'? I'm just a little confused.
It must be something with the device, then. I can't really think of anything else I could do to fix it.
Must be. On every device I've used it with, it's always discharging.
Sent from my HTC One using Mobile Nations mobile app
I have the S4 and it says "Discharging". That's odd that it is not saying the same for you.
mannanqureshi
