It may also be a "feature" set by your carrier - if you disable wifi, mobile data automatically comes on, so you're never without an internet connection (and you use more data). Some carriers are like that. (If that's the case, and you can't flash the older version [or don't want to], your only option may be a custom ROM based on the updated version, but without the "feature".)
