Decent Battery Replacement
HAVOK#AC
3
Bought it on the bay, came from California, original box appears to be from Hong Kong. Had it for almost 5 days now, been holding up pretty good but then again I'm not a big battery hog but that 1230 mAh just ain't gonna cut it. Cost me $25 shipped. It seems to be a replacement battery for the Desire HD showing 1600 mAh. Here are my settings:
*Not Rooted*
Screen Brightness: 15%
Wifi: On only when I'm at home.
Auto-Sync: Off
Data Network: On only when I'm out.
Widgets: Clock (3/12) & Friend Stream (2/2)
Updates: Set to manually when the app is open.
Weather: Every 3 hours.
Vibrate Feedback: Off
LED Notification: All Off
GPS: Off
Normal daily usage is about few 5 minute phone calls, dozens of texts, about an hour total of web browsing, couple pics here and there, and perhaps 30 minutes of music via headphone when I walk my dog.
Stock Battery (100%): 13 Hours till the next charge
Aftermarket Battery (100%): 60 Hours till the next charge
I don't know why the link isn't working for me but anyways here's the item number, just put it in the search engine.
250779541146
I know it says "1500 mAh" in the description but mines arrived with a 1600 mAh. Anyways, this is just my input on this battery. I'd recommended doing as instructed by charging your battery 4-6 hours before inserting it into the phone.
Just ordered the same thing on EBay for 11.00 dol. Comin from china on the slow boat but its the same thing ca. is puttin out. If you dont need it right away a few weeks isnt bad to wait. Glad to see people are fing these jewels:D
It will be interesting to see how well the aftermarket batteries last/work, I'll be following this thread for updates from the members who buy them.
I just ordered one through ebay yesterday. $25 including a wall charger with usb port. Couldn't go too wrong imho.
I'll post after I've had a chance to use it.
Batteries
I have had these same ones for about 2 weeks. So far, so good. Mine were 1500ma. Definitely notice improved battery life - too soon to tell on how long they last.
Do you have an item number for the $11 one?
OK I got the 1500 mah battery off Ebay. 100 smaller then the 1600 you guys talking about.
I use the phone pretty good and today I put it in around noon and finally drain it about 2 am. This upgrade of a battery is a god sin. I use my apps and browse the web and use Pandora all at once but it was off and on all day mostly use the apps and internet but still hold up. The stock battery would been dead after 5 to 6 hours of used.
All I can say is once you get the phone upgrade the battery ASAP.
Got the 1600mah batt via ebay for about $25. Pretty much a waste of money. Life is half what the stock batt. gives me. I'm contacting the seller for an exchange. Maybe I just got a bad one?......
Are there any "official" 1600mah batteries that are compatible with this phone? The batteries on ebay seem like a good deal, but if I have to wait for 4-6 weeks for it to get delivered from Hong Kong and possibly getting a defective one, I'd rather just pay full price for one and get it right away.
With everything that has happened in Japan, you may want check if the batteries are radioactive.
*Not Rooted*
Auto-Sync: Off
GPS: Off
So a battery that has a 30% higher mAh is giving you a 450% improvement? Calling BS. On that.
For what it's worth, 1st day with the Seidio 1300mAH battery: After the initial overnight charge - I'm at 16 hours of having the phone on without shutting it off or recharging and I'm at 38% according to the HTC battery widget ;)
My ebay seller is sending me a replacement at no charge. No exchange necessary. Keeping my fingers crossed. I gave it a full overnight charge and am down to 22% after just four hours. I have my stock batt. with me for the inevitable swap out. Side note: is anybody elses batt. cover showing signs of fatigue from removal?
HTC will replace your battery cover for free if you go to their website and call CS and let them know
Good.. So you're not the only one. I also got the 1600, and am experiencing the same result. The charger it came with has to be fiddled around with just to get power output.
LilmissSunshine
