Deleting Gear S Contacts?
Douglas Yarnold
58
I have multiple contacts on my Gear S Contacts that are NOT on my Samsung Note 4 Contacts.
How do I delete Gear S contact information?
Resolved: Found on an earlier post to this Forum:
Go into your contacts and select the group icon, there it should say "Not Assigned" then you can delete them.
I have none that say not assigned. I actually had found a solution back in 2014 that worked.:
type in the identified unwanted name that is popping up on the Gear S contact list into the Phones contact search bar. Press and hold down on any contact. At this point the contact list switches over to another screen. Type in the unwanted contact. (The contact is hidden otherwise unless it is done this way.) Simply check and delete the contact from your phone. It will immediately be deleted from the Gear S.
It now doesn't work for me either. Is Lollipop different?
luizamarns
