Difference between BAMF 1.5 and BAMF 1.5 Remix
Das BAMF Base Features:
--Debloated, which includes vzw framework, apps, games, libs, and permissions.
--Tweaked filesystem and minfree.
--Zipaligned (just once, not every boot, sorry), and deodexed. Odex and deodex perform the same after the first boot, when deodex roms get....odexed. This is merely to save space in /system and make tweaking easier.
--Added Google Car Home, removed HTC car app.
--Removed drm apks, and framework for now. If Netflix requires it later, I'll add it back.
--HTC Hub and htcsense.com are partially working.
--Removed Stocks widget, and app. Google has better apps for this anyway.
--Supruser is fixed with rmk40's version, woot woot!
--My own busybox, version 1.19
--Disabled data auto restore, because it tends to interfere with titanium backup.
--Extra scripts
sysrw --sets system to rw.
sysro --sets system to ro.
uber_quadrant --boosts your quads (for fun, must have quadrant installed. advanced or standard is fine).*
rw_boot --sets system to be rw every boot.*
ro_boot --sets system to be ro every boot.*
*don't mind errors if you see them, it will still work.
--profile added to system/bin to help prevent certain malware.
--Kernel has init.d support, as well as adb root, and usb debugging enabled on every boot (even from a wipe).
--Dusk theme from HTC Skin - "Dusk" Sense 2.5 (Z based ROMs) - xda-developers
--No location indicator, thanks Bgill55!
--No recent apps on notification bar. Inspired by http://forum.xda-developers.com/show....php?t=1004975, using 1.12.605.9 framework, which appears to have quite a few fixes, at least in xml.
--Transparent pulldown and location reticle deleted
--Modded launcher to include 5 app/transparent app drawer.
--Deleted am/pm in status bar clock and carrier in pulldown
--Accurate battery and custom super quick transition animations
--Added Spare Parts to speed up animations even more (change animation speed options to fast for best perfomance)
--Latest maps. (1.4)
--Settings toggles, credit to sk806 and JSChiSurf. (1.4)
--Settings toggles control app, credit to sk806 and JSChiSurf. (1.4)
--6 bar signal mod, credit sk806. (1.4)
--gps enhancement, credit to ziggy471. (1.4)
--Custom Das BAMF skin, credit to gadget! (1.4)
--Custom Boot animation, credit to dsb9938. (1.4)
--GoogleBackupTransport.apk is back for those who want Google to restore your apps. (1.4)
--Some minor build.prop tweaks. (1.4)
--32! tab browser, credit jcase and ThatDudeButch. (1.4)
--Rebot options, including hot restart, credit to aiccucs. (1.4)
--sndoff script: Use with su, turns off boot sound. (1.4)
--sndon script: Use with su, turns on boot sound. (1.4)
--Transparent drop down. (1.4)
--Dalvik heapsize increased to 48M. (1.4)
--Custom 1.4ghz kernel: (1.4)
Supports tun
Supports nfs
Uses CFS CPU schulder
Uses BFQ I/O Scheduler
Governors: Ondemand(Default), Powersave, Conservative, Interactive, Performance, Smartass.
10 speed steps: 245/368/576/768/806/960/1036/1228/1344/1420mhz.
Undervolted all the way to 1036, stock voltage at 1228, slightly overvolted for 1344 and 1420mhz.
Kernel will boot at 1036mhz! You must use setcpu to overclock, the kernel will not do it for you automatically.
Battery charging enhancements.
SLQB Slab Allocator.
Updated ashmem driver.
GPU+ patch.
Death Ray support (Ultra bright torch. Requires app support, included with toggles).****
Audio enhancements in kernel.
Teeter (1.5)
HTC livewallpaper that rotates images (1.5)
In addition - Das BAMF Remix includes:
-Custom accurate battery with new smooth charge animation (1.4)
-Dark themed UI including market (dialer and other elements still to come) (1.4)
-Square edged menus (1.4)
-Transparent and 5 column app drawer (1.4)
-Themed rosie with transparent background and new minimalist buttons (1.4)
-Rosie now remaps "personalize" button to Rosie Settings in app drawer, launchkey removed but can still be installed and utilized via Rosie Settings to launch an 8 item menu (1.4)
-Clear lockscreen (1.4)
Reactions: aplsucks
Thanks JTM!
Which seems to be more popular?
Not sure which one is more popular, but i went with Remix.
The great thing is you can try each one out, see which one you prefer, and then stick with it. That's why i love Android.
Make sure oh nandroid,just incase you don't like the Rom you flash. Reverting is a simple operation once backed up
I'm on the 1.5remix as well
TboltMeatclaws-talkatap
I am currently running DB 1.6 base. If I was to flash 1.6 remix, would that require a data wipe? Or can I get away withjust wiping the caches?
luigui443
