Ditching the screen protector, going with the belt clip cover system
jeffmd
563
So since release I have been sporting a wet skin based protector while waiting for a suitable glass. The polyurethane skins are great protection but 3 huge issues, #1 it doesn't feel good, #2 in applications like the Gear VR where you are magnifying the surface of the screen the deformations in the protector and minor distortions it creates are visible, and #3 the curved glass makes the edges sensitive to peeling, especial when it is hard to create a case friendly skin without making the edges higher and thus a bigger target for your thumb to continuously rub against.
#3 was the most destructive for me, despite using poly skins for many many years now I never had to tear one off because the edges started to peel. I have twice had to install skins on my s8 and both times my cases immediately caused the skins to start peeling (Second time I waited 24 hours for drying). This was compounded by the need to remove the phone when ever I wanted to use the gear VR.
The only thing that really materialized for glass protection is the whitestone, but fro $40 it seems to be too much of a gamble for me to attempt with my heavier duty cases. Even on the off chance the first time I slap the phone in a protector the whitestone survives, but what about the many other times I remove and reinstall the case? if the whitestone has shown me anything, it is that it clearly backs up its claim of the screen being easy and clean to remove. I need something that hugs atleast as tight as the polyurethane skins.
Alternatively I have considered case options that would ditch the screen tight protection and offer screen protection elsewhere. The majority of choices here is wallet style cases, but again I found 2 critical flaws in this category. #1 most cases didn't offer a suitable clasp (if any at all) and #2 %99 of them offered no special protection over the screen contact point, with most of them sticking a slot for credit cards and stitching for the lip of said slot to rub up against the screen, easily allowing an abrasive surface for the screen.
In the end I went with a belt clip, namely I went with Supcase's Unicorn Beetle Pro as it was very affordable while meeting my construction standards. At home I don't do much with the phone to worry about anything getting on the screen to harm it, and outside of home the phones belt holder completely shields the screen while not getting within touching distance with it. It is a little bulky on the hip (but should be far less so then if I was sporting a wider 16x9 phone) and may take time to get used to, but I think it will be a good trade off to feeling safe with sporting a naked screen. If the belt clip simply does not work out I can always remove the clip (with considerable force) and still use the plastic clasp as a cover in the pocket. So far the only downside is it is a little hard to remove the phone due to the plastic frame that snaps over the front, but I can't knock additional protection like that. Also as a fan of the commuter cases, I am happy to have my port covers back (I have a "plug" for the headphone jack so I can sport cases without covers, but didn't have one that would fit the usb-c port).
Would be interested to hear if any others choose this bulky case route (normally I have no reason for a belt clip, my phones have never been an issue staying in my pocket at work) as an alternative to screen protectors while out in the wild.
I use Qmadix Liquid Glass Screen Protector and an Otter Box Commuter case with my S8+. The liquid protector gives the glass 9H hardness but doesn't increase shatter resistance, they do however offer $100 towards your glass replacement if you manage to break it. I've always hated screen protectors for a variety of reasons and the liquid stuff is like it's not even there.
I have the QMadix liquid glass as well. Since Gorilla Glass 5 is more prone to scratches but less prone to shattering, the QMadix adds some scratch resistantence. They and a case and I haven't had any problems. Even after accidentally dropping it a couple times; once with it landing on the display.
Gorilla glass isn't even the slightest porous, nothing you rub on to it is going to make a big enough layer to do jack.
Put the liquid screen protector in a glass that would scratch easily like an old eye glass. Then test with a knife if it will really protect it. No use testing it in a gorilla glass.
Not sure where you heard that but AAS Glass (Gorilla Glass) is actually quite porous. The potassium ions go deep into the glass when its chemically strengthened and is also what makes Gorilla Glass a bit stronger than other glass. This is what allows nano coatings, such as qmadix, the ability to cure to the glass.
Got a clear plastic back-only case. But I'm changing to a leather folio as it seems the only way to protect the S8+ without armour plating. I don't do screen protectors--glass or otherwise.
Doug, still need screen protection from that flap, that flap will press in on any junk that finds its way onto the screen.
Mav, thats a nice find and a good idea if it still ment relying on polyurethane protection. The price is kind of painful, doesn't seem to be any cheaper then $15 in the US..$10 if I want to wait 2 months from korea.
I have Prime and it was $11.99 for the two pack.
What prices are you seeing?
Mav.
When I clicked it yesterday the lowest price vendor was $15. it is 11 bucks now, but the 6 bucks shipping for us common folk is weak.
I have been using the Otterbox Strada Leather flip case for about a month with no screen protector and I love it. I went through 3 screen protectors and got tired of them falling off and the horrible sensitivity issues. I have small microfiber cloths everywhere...at home, in car, wallet.. I use them ONLY to keep screen clean. If you keep it clean, the flap wont cause any scratches. Yes, if there is chunks of sand on your screen, scratches could happen. Mine is spotless so far. Just be smart and not lazy. Btw....I don't use the slot for credit cards....don't want to risk a scratch
I bought a glass screen protector from Best Buy when I got my phone. It is working GREAT with my Mophie I have on my S8+.
I got zagg hd wet clear at best buy.Had them install it the girl said the trick install ing it is make it as high as u can so the bottom has a gap so otter box defender case doesn't hit it and wait 36 hrs for it to dry before putting case on it.Looks great no problems.
Same. I had a wet install on my Edge and it did a great job and was $8, but vr and touch were uggh.
I have a full protection case and a leather wallet case, depends on what I need for the day.
MercedeZ
