- Apr 9, 2014
- 2
- 0
- 0
I downloaded the Dodol Launcher app and I feel like my battery is draining faster, although I could be very paranoid.
When you switch to a different launcher, you may want to clear out the original launcher from the phones memory. The phone may keep it in memory for a little while before it needs the space. So basically you'll have two launchers running for possibly a couple hours at most depending on how much you use your phone. Not sure how long its been yet since you've switched them, but that could be a minor reason why. A launcher really should NOT drain any more battery than the stock launcher.
That shouldn't affect battery life enough to make it noticeable. The RAM will be more full, but that's about it...
Sent from my Galaxy S4 running SlimKat 4.4.2
I always kill it because I usually have a couple syncing widgets and I don't want those to keep running.
Sent from my HTC One_M8 using Tapatalk
