Do non stock launchers use more battery
stephanie85
83
4
Was just wondering if non stock home launchers such as Launcher Pro or ADW use more battery than the stock TW ....which are you using and why do you prefer over TW ...thanks
I use Go Launcher Ex and still get great battery life. Never tried the other two you mentioned.
I'm using Launcher Pro along with Widget Locker and it did not effect my battery life either up or down.
Ditto with go launcher. No decrease in battery life that I could detect.
Now if only go launcher could get rid of the annoying gap at the top of the screen. Even when you disable the page indicator the gap is still there and widgets don't align to the top edge of the screen :(
kaiju8
