Does EasyTether Pro work on Android tablets?
Casey Cheung
1,234
5
EasyTether Pro works well with my Thunderbolt connected via USB cable to my various Windows laptop computers. Will EasyTether Pro also work with Android tablets, such as the Toshiba Thrive, etc? Thanks! Casey
Don't think so... you could try PdaNet using Bluetooth otherwise I believe the only other way is to root your phone and use the free wifi tether or barnicle wifi tether apps.
Download the free lite version of EasyTether and test to see if it works... I'm pretty sure it doesn't though,.only works with laptops.
Reactions: Casey Cheung
Ariwenni15
