Does FoxFi Wireless Wifi mode work on the Verizon Galaxy Note Edge?
Ismael Pulido
Does FoxFi, Wireless Wifi mode work on the Verizon Galaxy Note Edge?
I know it has work on other Samsung phones like the note 3 and 4. Thank you.
Have you seen it work or did you get your information some were else? The reason I ask is because I'm thinking of getting a Samsung galaxy note EDGE, and I really need Foxfi to work on it. It's a big experience for me and wouldn't want to spend the money if it doesn't work properly. Thank you for the previous response.
I have a Verizon Note Edge that I use with Cricket (AT&T). I'm successfully using FoxFi on stock Verizon Note Edge ROM.
Sent from my SM-N915V using Tapatalk
I am purchasing a note 4 edge today. What do I need to do to bet a free hot spot. From reading rhe forum it looks like I need foxfi but I do not know how to do it. Can someone olease give me some assistance thanks
Just install the free FoxFi app from Google Play Store. Launch it and configure your desired hotspot SSID and password.
It works on mine. I'm using my Verizon Note Edge on Cricket/AT&T.
Does anybody know if Foxfi will work on the Samsung Galaxy Note Edge after Verizon's latest software updated?
It does not work on the HTC One M8 and I'm afraid to update my software and lose using Foxfi.
Yes, it does. I've been using it off and on with no issues.
"Does anybody know if Foxfi will work on the Samsung Galaxy Note Edge after Verizon's latest software updated?
It does not work on the HTC One M8 and I'm afraid to update my software and lose using Foxfi."
bohanvo2
