Does Foxfi work for VZW Gnex with Jelly Bean? If so....
Ivanamanation#IM
198
How is the speed? Is it the same as when you were on ICS? I'm thinking about upgrading to JB today, but I don't want to lose Foxfi.
works perfectly fine from what I see. course there is a wifi tethering application built in the device that works well too..
I'm having problems with a constant connection.
I have both fox and svtp installed.
What else do people use?
So you use it without any problem, right? Or do you have to turn on the Wifi tethering on your phone?
Just dl'd and had no issue... It says only works with jb on vzw gnex
You just turn it on and it clicks on the tethering immediately.
My problem is getting into to stay connected.
JOLOVELY24
