does it keep the correct time? what happens after battery is completely dead?
badkitties
880
does it keep the correct time? what happens after battery is completely dead? does it remember the time once I charge it again? (out of wifi or bluetooth range)
Been using my Fit 2 for just a couple of days now. Time accuracy is spot-on, all the time. Haven't run it out of battery, but I'd venture a guess that it would work much like simply turning it off. It should be just fine. Once recharged, I'd expect everything to be as it should.
Hope this helps!
Hope this helps!
Thanks! I guess only time will tell. (get it? time? :D )
The reason I'm asking is this... on my Note 5, Note 7, S7 edge and other Samsung phones, if it's out of data connection(either cellular or wifi) for more than a couple of days, the phone's time become off by minutes and sometimes houre. Granted, the only happens if I forget and allow the battery to go completely dead and don't charge it that same day. It happens a lot when I was travelling in Europe and had the phone in airplane mode all the time. (mostly using the phone as a GPS with Google Maps offline maps)
chzahid600
