Does Netflix work with Cyanogenmod 9/10?
6tr6tr
1,211
14
Does Netflix work on the Galaxt Tab 10.1 with CM9 or CM10?
(I ask because on Samsung ICS, it freezes while playing movies after about 10 seconds or so)
I have the same problem with an Htc Evo 4g. But I still think its a great Rom (9).I will use it for a while. Maybe they will come up with a fix. Besides everything else works. Hats off to the devs, Thanks
Wow, I had no idea it wasn't just Samsung's ICS version. I have CM9 on my phone and can run Netflix, but the tablet won't run it.
I'm running CM10 and Netflix works fine on it.
Are you on an older build???
I'm running the 8/16 Experimental build and the built in kernel on a Wifi only Tab.
Sent From My GalaxyClass StarShip 10.1/4.1.1(jb)
That's good to know because I called both Netflix and Samsung and neither one seemed to care or think it was their problem, so a fix is unlikely.
I am running ICS stock on my GT10.1 with NO PROBLEMS. I am connected at home via wifi and on the road with my AT&T wireless that is a year old. it migth be ayour connection. There is no buffering freezing or pixeling.
scoobyd031883
