Does the Note 8 have a removable battery?
TheLostPath
4
Hello, I currently have the Note 4 and have had it since Day 1. The phone is awesome but I'm debating on getting the Note 8, the biggest thing would be if it has a removable battery or not? I enjoy this feature because the battery is the first thing that goes out on a phone and replacing the battery is far easier than replacing the phone. Also, doing backpacking trips, festivals, or anything where I am not near a charger, it's a must to bring extra batteries due to my phone being my only camera I have at the moment. Just seeing if you guys could help me out, I really hope it does have removable batteries, if not, I'll probably just stick with my Note 4
it doesn't, but the Snapdragon 835 makes battery life awesome and consider the colossal upgrade you will be getting as well.
Thank you for your reply! As far as the colossal upgrades, which do you speak and what can it do that the Note 4 can't?
Removable batteries are a thing of the past...
I was the same way as you. just get it. you will not be disappointed, I promise. and it is an amazing device.
There are many changes from the N4 to N8, more then can be listed in a post. Suggest you look at this thread, it will give you a good idea:
https://forums.androidcentral.com/samsung-galaxy-note-8/831995-things-you-discovered-new-post.html
Also, to address your charging questions, there are many very good charging bricks on the market that will give a full charge two, 3 or more times.
Perfect thank you for this!! I will look into it. I do have 2 charging bricks 20,000mah, one for myself and my girl friend. They do come in handy!! I just find it easier to change the battery when needed and then charge overnight. Thank you again for this article!
Moderators you can close/delete my thread. My apologies if this was a redundant thread but it seems to be a target for bad company. I have my answer and PJRed2008 was extremely helpful!!
salesteamnews
