Does your LED work?
Does your LED work?
  • Total voters
makewayhomer
23
BY work, I mean
- lights up when charging (edit - I'm not 100% sure if this is supposed to work)
- consistently lights when an email/txt comes in
if you fixed this problem via app, pls answer as your phone was "vanilla" before app..though fixes are welcome
It works...the problem is you can't really customize it too much without a 3rd party app. Like others have suggested...lightflow is great.
I just tried lightflow and it didn't work when I tried the "test" function in the notification config menu. Hm.
I just tried lightflow and it didn't work when I tried the "test" function in the notification config menu. Him.
Did you wait for the screen to go dim or turn it off with the power button after you started the test? It will not flash while the screen is lit.
Reactions: Pierce09
I did hit the power button and nothing happened when the screen shut off. I'll try it again.
I just tried it again and it worked. I didn't wait long enough. It took a couple seconds for the LED to kick on.
Lighting up when charging would render it useless for notifying of events while it is charging...
Does light flow let you change the color? Is that even possible?
I'm using the Light Flow app and the LED does come on while the phone charges.
That's an option...you can turn it on or off when it's charging. Whatever you like.
My only issue with lightflow is that when your phone is locked and say you get a text message. Your led lights up, you turn on your phone and swipe down on your notification bar (without unlocking)...you see the text and say it's only a few words so you can read the entire thing in the "preview" on the notification pulldown. You swipe to dismiss it (or press the X to clear them all), but the lightflow continues to blink the led. Kind of a drag. You have to go all the way into the text message to look at it before lightflow thinks you've paid attention to the notification. Kind of lame and hopefully they fix that. Gonna send an email to the dev.
aimalee
