Double Tap for Voice Not Working?
Citymusic08
Active member
Jul 16, 2011
25
6
The motion "Double Tap" feature does not work properly for me outside of the tutorial. Inside the tutorial, it recognizes the taps and congratulates me on a job well done. Outside the tutorial, the double taps are not recognized and do not initiate the voice app. Yes double tap is checked. Are there any fixes/suggestions?
Yes I noticed that too, spend some time on it, thinking its just me...Thank god I did not use a HAMMER to tap..:-)
Its not that it doesn't work. It just doesn't work as expected. The double tap doesn't work outside the app like you think it would. Inside the app it makes the voice recognition start and the app waits for a command. I only figured this out after playing around with it for a while.
Well that's disappointing. I kept double tapping my phone this morning and wondering why I wasn't being served eggs and toast. :p
Yea I kept doing the same thing. My hand hurts. If you have to open app is is easier to tap screen. It would be nice to wake it up with the double tap. I had a jawbone headset that did just that with this phone. I returned it though. I could not hear phone ring while mowing lawn. Now I downloaded my entire music collection from PC and use ear buds. I can hear music. When the phone rings music lowers and I can answer.
isaackse
