Double Tap?
recDNA
8,784
160
63
Does the Note 8 have double tap to turn the screen on or off without locking which would require entering a pin? I don't mind using fingerprint but any apps that lock the screen that I know of require actual pin entry rather than any biometric means. PITA imo
Double tap the virtual Home Button will take you to the lockscreen if that helps. On my s8 I set my ZenWatch 2 as my trusted device so would only have to double tap the home button then swipe the screen to unlock. Or simply long press the home button. Nova Launcher has a setting to double tap for locking the screen again
The problem with Nova's setting (and a few other launchers and apps) is that when you double-tap to lock on the Galaxy devices, when you swipe to open your device (or use your fingerprint), it won't unlock. The only way to unlock at the point is by using a pin.
Nova has a way around that, I am using there double tap. It shuts the screen off for 10 seconds and then it locks. Doing it that way makes it so that you can open with FP or in my case smart lock.
That's what I do in different phones and it works fine. You just need to select 'timeout' as screen lock method in Nova settings.
BekaH
