Droid Bionic Problem
tscags83
I've had my Droid Bionic for 2 months and recently have been having issues with it. When i'm in the house i all of a sudden lose a signal and i have to restart my phone. It even happened once when I was outside. Tonight I had to yet again restart my phone and the screen stayed on the powering off screen. It never shut down so I had to pull the battery out! Now it's fine.
Never happened before? Could be some app you recently installed then. Check through stuff you recently installed and make sure you don't have something screwing you up. Even legit apps could cause problems if you just got a bad copy, might need to remove and reinstall fresh from the market. If nothing else works and rebooting didn't help, factory reset?
3G or 4G? If you're on the fringe between both, sometimes signal will drop. It's a known issue that will be addressed in an OTA update sometime in November.
3G or 4G? If your on the fringe between both, sometimes signal will drop. It's a known issue that will be addressed in an OTA update sometime in November.
Yeah this could be true that can cause it, but since he said he had it since launch or so and only just started having that issue I assumed that wouldn't be the case and its more likely to be something he just did to the phone, i.e. app install or setting that got screwed up.
Check your battery mode and see if you have the battery mode on Maximum Battery Saver.
Could also be a problem with your closest cell tower. Does this only occur when you're home?
Nicoloks
