Droid Maxx to Note 3 but missing Smart Actions and Motocast any suggestions
Ryp11
77
The title pretty much says it all. I love the note 3 but I'm missing Motocast as I loved how my pictures would automatically go to my PC. I also like how the smartactions would turn on the wifi when I got home or at work. I'm sure there are other apps that can do that and I would like your opinions on which ones are the best. Thanks!
You can use Tasker for Smart actions features. Imo, the smart actions is easier to use, but Tasker is more powerful. There are other options like llama as well
I have an eyefi card for my camera and I have it set up so that all pictures from both my camera and phone are automatically sent to my computer
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
I use an app called Trigger from the pkay store. it can use location to do things similar to smart actions and also nfc tags as well. My smart action only worked periodically anyway.
Sent from my SM-N900V using AC Forums mobile app
I don't think I could live without smartactions! Its such a helpful app. I also need a similar app for a Sammy phone on my account. Tasker is... a bit confusing and I don't have the patience to learn it to install and set up on a phone that's not mine, LOL
Thanks do you use the Trigger Pro or the free version? Any suggestions on a Motocast alternative? Thanks for the help
Try Agent. I've not used it, but it may be something like what you're looking for. Tasker is awesome, but I've found it very difficult to use. Agent looks to be a little more intuitive.
Juice defender used to be my go to app, on previous phones. but i havent tried it on the note 3 yet. Of course the paid version is better, with more options, but since i now have nfc tags every where, i use them to turn on/off settings, and trigger certain commands. plus, nfc doesnt drain my battery significantly.
shahindaosama22
