I'll be sticking with the razr as this upgrading every month out of contract is getting pricey. I love it, mainly due to size and weight. Anyway, this issue is not a Motorola only Issue. I had the problem on all 5 4g Phones I have owned. HTC, LG and Motorola. Everyone I know with the different 4g Phones has the same issue. So we are not alone. Motorola has a fix coming out this Month, and VZW is more than aware of the problem. If a rep tells you to reset your phone, tell em to piss off and research the issue a little better. Currently there is a setting you can change deep within your phones menu that helps with the hand shake between 3g and 4g. It will cause your data to drop out for a minute while switching between services, but will also keep you from having to reboot or flip on and off Airplane mode to get data back.
