DROID TURBO 5.1 Lollipop: Tasker Not Working For Me
Sure. The app was set up to shut down background data and disconnect 4g when the screen timed out as a trigger. Then when the screen wakes up it would reconnect 4g and sync background data. After the update it does nothing. Paid version too.
Thanks for asking. I would find it hard to believe its a lollipop issue because it works on my nexus 7 and nexus 10. And suggestions would be appreciated.
Stupid question. Did you open app and accept new tos? Mine wasn't working until I cleared that screen.
I'm just wondering if there's some settings g I need to change or possibly reinstall tasker
Droid guy are you rooted?. I have the paid version of Tasker
No root. Did you fdr after going to 5.1? Wipe cache partition and if that doesn't work then fdr. You should probably fdr anyway after the update.
DestiRizz
