Droid X / Mac / Dropbox help
Hipgrncln
Active member
Jul 30, 2010
34
Trying to make my Mac and dropbox work. My doc's from my old word processing program do not work. They were old cw files. Loaded I work 09 and the pages files do not work either. They are not recognized. What can I do ???
Bob J
Your question seems misplaced. If you need help with iWork not recognizing a file you need to find a forum about iWork. Your problem has nothing to do with the Droid X or Dropbox from what I can tell.
Old files were cwk. Iwork works perfectly. Mac works perfectly. Dropbox works perfectly. Android platform cannot recognize doc from computer. It will not open doc. This is not He said....She said. Just a Droid user trying to use or find software thatr enables me to make notations or lists on my computer and view and change them on my smart phone. Any help would be great.
Bob J
Bob J
So your question isn't about Android (the OS) or Dropbox, you are looking for an app that will read/edit .cwk files? I don't know the answer to that, but I would retitle your thread so you attract posters with this knowledge, rather than people coming to help solve a problem with Dropbox, since you don't seem to be having one.
BTW, can you just save your original files in a more useful format?
I guess then my question is what files/doc's will be acepted on the Android platform. My phone keeps telling me that an ERROR occured and I cannot read any document in Dropbox on my DROID X.
Bob J
