Droid x won't boot up until battery is removed and reinstalled
bronco252
9
Droid X, Rooted, GB 2.3.3...I've had this problem for the last week or so and can't seem to figure out why after a power down and back up it will go past the red ball and just sit there, never coming on. I can see the screen is at low light but nothing ever happens. I can then pull the battery, reinstall it, power up and everything seems okay. I don't really know when this started since I rarely turn the phone off. It seems any reboot I do does the same thing. Anybody else had this problem? The searches I found didn't seem to fit my problem. Any help would be greatly appreciated.
Thanks,
Mark
Thanks,
Mark
That's a new one for me. I have no idea, I would just SBF and see if that works, what an annoying problem that would be.
Sent from my DROIDX using Tapatalk
Thanks,
Mark
If you have bootstrap, then I'd try erasing cache and delvik cache first. If that don't work then formatting data would be next. If that don't work then I'd just do a SBF.
Sent from the future on my Samsung Galaxy S 3!
Re: Droid x won't boot up until battery is removed and reinstalle
I have the EXACT same problem. It drives me crazy. I really don't want to reload everything. Sure hope there is an easy fix for this.
NameRingtone
