- Nov 28, 2010
- 7,239
- 2,519
- 0
* DroidX Guide to Rooting, Backing Up and Installing Custom ROMS *
What you will need:
1- You will need a file manager, I use Astro..(app found in the market)
__________________________________________________________________________________________________________
2- Here's a video on installing Z4root:
YouTube - How to Root Any Froyo 2.2 Android Phone using Z4Root
Here's the download link for Z4root :
z4root.apk download
___________________________________________________________________________________________________________
3- Here's a video on using Titanium Backup Pro (app found in the market):
YouTube - Titanium Backup for Android (How to backup and restore applications)
4- Easy way to install custom ROMS with ROM Manager video tutorial (app found in the market):
YouTube - Motorola Droid - Easy installation of Custom Roms, Rom Manager!
OR
4a- Installing custom roms with Bootstrap video tutorial (app found in the market):
YouTube - How-to Install ROM's on the Droid 2 and Droid X (example: Fission 2.1 by TeamDefuse)
NOTE: If you plan on using Rom Manager, you will also need Bootstrap installed in order to boot into Clockwork Recovery. Rom Manager will not work without Bootstrap..... however if you just plan on using Bootstrap.... then that's all you need.
* And that's it...you are all set to go *
Extras
1- Droid-X Overclock/Undervolt Tutorial using JRummys Droid X/2 Overclock(app found in the market):
YouTube - How to Overclock/Undervolt the Droid X
2- List of all custom ROMs for the DroidX (I like using ApeX):
Droid X ROMS - HERE
3-Full list of apps and apks that are removable and non-removable:
Full-list-apps-apks-removable-non-removable (removing Verizon bloat)
4- Return your DroidX back to Verizons factory stock conditions (2.3.340 Froyo) ..includes Verizon's bloat apps like Amazon, Blockbuster, etc..
Full SBF 2.3.340
Or
4a- Even easier, flash this zip in ClockworkMod Recovery:
Maderstcok-OTA-2-3-340-update-zip
Last Updated: March 15th, 2011
