Drupe recording call does not work
monkeycsk
582
185
43
anyone uses Drupe for recording calls?
after the recorded call, i can not hear the other party at all, only my voice.
there is absolutely no settings in Drupe that i can see to correct this. anyone has the same problem??
@donm527,
thanks for the quick reply. this is a (trial) unreleased version and absolutely no reviews from any user.
i was curious if anyone has feedback or comment about this new app.
@donm527,
There are a number of call recorder apps that aren't working for N8's and other Android phones on Nougat 7.1.1 that were previously working on 7.0 and older versions of Android.
A number of us ARE using Call Recorder by SKVALEX and it's working pretty much perfectly. A couple of quirks, like if you muted the call, but for the most part recording both sides of every conversation, including Bluetooth calls (which my previous app, Automatic Call Recorder Pro never did).
Here's the conversation about it:
https://forums.androidcentral.com/showthread.php?t=831738
Also, I believe most apps that are Trial or Beta do not show reviews in the App Store, instead send the comments directly to the devs.
