dust gets under op3 edge to edge tempered glass
I have not seen dust under the screen protector yet, have had it on for a little over a month. I have had dust get in-between other ones, but not the OnePlus protector yet.
I don't think the TGSPs adhere completely to the surface of the phone like the soft plastic ones.
So the TGSP from OP adheres completely to the screen? Good to know. Thanks. Does it work well with cases like the Spigen Rugged Armor?
I have the Spigen Rugged Armor and so far it looks fine. I have had it for barely a week though so can't tell you about longevity.
Good. If that works well, I may have to come up with some accessories I need to buy to justify getting the OP TGSP. ;)
Hi there,
are you refering to the Curved Temp glass from OnePlus? or the regular Temp Glass from OnePlus?
Thanks
Hi there,
Thanks
I was assuming they're talking about the curved one, since that's really the edge to edge protector that they're referring to. But I could be wrong.
SKGcoshatt
