DX Help
detfan
48
I just bought a used DX, and it has a pattern lock..Can anyone tell me how to get rid of this so I can restore the phone? It is not activated yet so the gmail thing is out.Story is I bought one on ebay from a local person..They run a mobile store..It was great but the mic didnt work so I took it by there today to exchange it and got home and it hasnt been reset, and it has a pattern lock on it..I cannot egt a hold of them either so Im losing my patience..Any help?
The only way to fix it is to do a hard reset... Do the following:
. Turn the phone off.
2. Hold the Power and Home buttons down for about 5 seconds.
3. A screen with an exclamation will appear. Tap the Search key.
4. Scroll down to factory reset using the Volume Down button.
5. Confirm the selection.
6. Select Yes — delete all user data then tap OK.
The Droid X will then complete the hard reset.
Reactions: Smitty_82
MrSpock nailed this one. That should work. Too bad I didn't see this thread earlier, lol.
sportzfyapp
