Linda McDonald Well-known member Apr 20, 2013 187 0 0 Mar 30, 2022 #1 Had anyone had problem with not being able to hear through ear speaker when in call? And had anyone found a fix for it? Thanks
B. Diddy Senior Ambassador Moderator Mar 9, 2012 169,583 10,992 113 Mar 30, 2022 #2 Is there no sound playing at all, or does it just sound muffled? Does it sound normal if you turn on speakerphone?
mustang7757 Admin Moderator Moderator Feb 6, 2017 98,704 15,263 113 Mar 30, 2022 #3 First thing I would check if the ear piece is free from debris , it's pretty small and can get dirty quickly, safe mode would be next option and device care has a diagnostic tool to test the ear piece.
Linda McDonald Well-known member Apr 20, 2013 187 0 0 Mar 30, 2022 #4 Speaker volume is fine. Headset, fine. It's not muffled. It's just not loud enough.
fuzzylumpkin Well-known member Dec 7, 2012 5,551 2,569 113 Mar 30, 2022 #6 Are you holding it to your left or right ear?
J Jell Lee Well-known member May 27, 2021 86 0 0 Mar 30, 2022 #7 one option is to visit authorized repair center and ask for a checkup on the speakers
