Earphone connectivity problem
Avinash V Raj
Hi,
I am using Samsung Galaxy Y. My device dosenot detect my earphone now. It happened after I accidently unplugged my data cable without disconnecting it. I did a factory reset and after that it was working. But the problem reoccured after I synced my device with my previously synced gmail. I think there must be some services which is stopped or something.
Things which i noted.
  1. Earphone is working fine.
  2. Phone jack doesnot seem to have any problem.
  3. Some service seems to be disabled.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
162,607
938
113
How did you check the phone jack--just a visual inspection? Lint and other stuff can get stuck in the jack and interfere with the connection, and it's not always easily visible. Try blowing the jack out with a compressed air bottle, or use a damp toothpick and root around to see if you find any lint.
Ellekayh
