earphones problem
NomenNescio
My earphones, those that came with the phone, have suddenly gone mute on one side - the right. They worked perfectly fine so far, and the only thing i can remember having done with them is using them in my computer, which i have done before without problems, because my headphones also failed....what can I do?
Go under settings-device-accessabillity and scroll down and see if mono is ticked, if it's not check Sound Balance right above that. You could also try Adapt Sound and see if that does anything.
kiki2025
